Yeah, aerators need 1- ways and these restrict flow the least. They are just large brass 1- way flapper type valves.
Duffy's 2005 24v wakesurfing mod thread.
Originally posted by NICKYPOO View PostCool. I had just never seen that type before. They look pretty heavy duty. I like that.
It's looking good dude. Big, simple, effective. I like that as well.
All the rest seem to restrict flow a little, so I went with these.Build thread: http://www.tigeowners.com/forum/showthread.php?14787-Duffy-s-2005-24v-wakesurfing-mod-thread&highlight=duffys+24v
Tigé Jedi
- Jul 2010
- 4301
- TN USA
Originally posted by duffymahoney View PostHere you go. You can see the huge 1-1/2 flapper valve!
Also, where is your triducer? Mine is directly to the starboard side of my transmission, basically right where you have your pump on that side. On the opposite side in roughly the same space is my engine raw water pickup. That positioning in my boat makes a whole bunch of space unavailable for pump installation.
Originally posted by WABoating View PostWow, thanks! It appears you have more room than I do between your engine components and your stringers.
Also, where is your triducer? Mine is directly to the starboard side of my transmission, basically right where you have your pump on that side. On the opposite side in roughly the same space is my engine raw water pickup. That positioning in my boat makes a whole bunch of space unavailable for pump installation.Build thread: http://www.tigeowners.com/forum/showthread.php?14787-Duffy-s-2005-24v-wakesurfing-mod-thread&highlight=duffys+24v
Tigé Jedi
- Jul 2010
- 4301
- TN USA
Originally posted by duffymahoney View PostI honestly don't know where my depth sounder is, I think it's just the perfect pass paddle wheel one which is back a little bit from my port pump.
Mine is sort of centered between the engine and stringer, which prevents me from installing anything of any size there. Plus, I don't want anything disrupting the flow over my speedo wheel. There are whole separate threads here regarding cruise control issues and I often wonder if some of those problems are related to turbulent flow over the wheel.
I just cut in my thruhulls last night and all of them are on the opposite side of the keel from the triducer for this exact reason.
Originally posted by duffymahoney View PostI personally like them on the transom. That way if the pump has air lock, just put it in reverse for a few seconds and it's fixed
Here is the wiring harness. I did 10 awg to the battery and the rest is 12awg marine wire. All heat shrinked and cut and measured for the boat! Took like 4 hours to make! This is my third and I am doing dual bow ballast, and dual rear ballast. Total of 8 pumps! lolAttached FilesBuild thread: http://www.tigeowners.com/forum/showthread.php?14787-Duffy-s-2005-24v-wakesurfing-mod-thread&highlight=duffys+24v
