Duffy's 2005 24v wakesurfing mod thread.
    good idea keeping the bow sacs full.
    240 on the deck is crazy. That's like having Oprah hangin off the back of your boat
    my midlife crisis started at puberty and I plan on enjoying it all the way to the end..
      Heck yeah! I should be running 2600 in ballast per side all hidden.
        that's like 11 Oprah'sworth of ballast per side..lucky you don't have to feed sacs
          i don't know if the platform is goign to be touching the water or not but if the bottom isn't completely flat and level then you will still get "some" unwanted drag
            Got the 1.5" hose and wow is it big!
              damn you got some fat hose there sir
                {insert off-color junior high school humor here}
                  Should have ballast wired and installed this weekend. Pumped!
                    cant' wait for the first vid's of long fat shapely waves
                      x2!
                        Ok got my dual rear and dual bow ballast switch from Tige. Looks sweet! Does anyone know what the blue wire is? Accessories, ignition, dimmer? Goes to the top left on the switch.
                          How much did that panel set you back?
                            180. I know it's expensive, but came wired and looks stock! This is my 4th ballast install and switch location has never been perfect.
                              thats freakin sick
                                That's actually not that bad and you get the nice factory labels and panel.
