Quick tip for those finding it difficult or impossible to feed the new steering cable through the circular cutout in the floor under the helm:
When I tried this on my 20V, I kept hitting something under the floor that wouldn't allow the long metallic end of the steering cable to make it through far enough...turns out it was the gas tank. Before you freak out and go cutting new holes in the floor, take a look at the gas tank (assuming you have easy access to it by removing the floor panel like I did). There are 4 small black brackets with 2 screws each that hold the tank in place. Unscrew them, and voila - you can slide the tank forward about 6 inches (plenty to get the steering cable through). Don't forget to slide the tank back into place, and hopefully you were able to save some time and frustration...
