Hi,
This is my first post on the Tige owners forum. I hope I’m posting this question in the right place.
I just took delivery of a gently used 2018 Tige RZX2 two days ago. I absolutely love the boat except for one “slightly important” detail — I cannot for the life of me dial in a decent surf wake. I was able to obtain a marginally surfable wake yesterday, but it was much worse than what I’ve been surfing on a friend’s GS22 and even another friend’s 2006 Mobius. So I am clearly doing something wrong.
I just took the boat out on the lake this morning while things were calm to play around with settings. I tried different ballast fills including all ballasts full and then only back ballasts full and 60-80% full in the front and I also tried dumping some weight from the right rear tank. I tried every possible TAPS and Surf configuration and just couldn’t achieve anything respectable. At best, I end up with a very short, steep and very messy (i.e. tons of wash) wake. I made sure I was in at least 25+ feet of water.
My boat is equipped with the stock underfloor ballast plus the rear plug and play bags.
Does anyone have any recommendations for what I should try next? I am assuming I should at least be able to get a reasonably good wake with my current ballast setup without having to add lead.
Thank you!
Brent
Thank you!
Brent
