I took the picture from the post of the impeller change I wrote earlier.
Marine Power Impeller
This is a sticky topic.
Here is the Jabsco crossover for the Johnson 09-812b.http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT He sells them for $24 plus shipping, but he will accept offers. I offered him $24 delivered and he accepted it.
If you are in doubt pull the impeller plate on the pump to get the pump info and use google to determine your replacement part number. I have a 2004 24v with the Marine Power 6.0L. My pump is a jabsco 50410
http://www.jabsco.com/files/50410_fip_bro_flange.pdf
and my impeller from discount inboard marine is 29 bucks
http://www.skidim.com/searchprods.asp
I pulled the plate to make sure I was buying the right one. Not all Marine Power pumps are johnson, it can be either a johnson or jabsco
Pulled the impeller today as part of our winter storage. It is the Johnson 812 B1 impeller in the 307 Marine Power engine. Hoping that pulling it and putting it in a bag with some grease will help to keep it flexible. I'm thinking the heat and cold and sitting for months on end
are what really kills the rubber. We're buying a new one in spring and just plan on carrying this old one for a spare. I hate this time of the year... no more liquid water and no frozen water......sigh.
hey I have a 2001 Tige 21i and im not getting any water running through the motor. the motor is a 350 mag mercruiser. I check t-stat, acutally opened it to make sure it wasnt stuck shut. didnt fix the problem.. my next guess is that the impellor is burnt up/broke in the fresh water pick up.. any tips on replacing this or what part number it is?
I found your information in the technical overview section and since it looks just like the housing you have pictures of there I assume it is the 812 part. Thanks so much for all you do on this site! It is appreciated!
