Marine Power Impeller
This is a sticky topic.
    Does anyone know what kind of impeller that Marine Power engines use? Is it the same as what Mercruisers use? I have the Marine Power HT 360HP engine.
    Also does anyone have an idea on where the impeller housing is located? I am taking my boat on a small vacation and wanted to be prepared in case anything happens.
    Thanks
    It does not use a Merc impeller but a MAYFAIR/JOHNSON Impeller part number 09812B.
      Does the 6.0 L 400HP also use this impeller I wan't to do the same thing.
        Thanks lee. Where is the impeller pump housing located?
          Inside the little housing. The cover can be removed with a straight blade screw driver.
            lee, is this the same impeller part for a 340hp 5.7l enigine (2005)
              How about the '06 also?
                Thanks a lot lee.
                  Yes it is.
                    Lee is this the same?
                      Yes.
                        Lee, which is the right one or are they both the same?
                        https://www.overtons.com/modperl/pro...=29530&aID=10I
                        http://www.boatersdiscount.com/prodd...rod=189-09812B
                          The one from Overton's is right for sure and the other one I do not know.
                            Originally posted by Matt Garcia View Post
                            Thanks a lot lee.
                            Matt, did you replace your impeller? How was it? According to Lee's post, you can remove the impeller cover with a screw driver and not have to remove any belts or hoses. Please let me know. Thanks, TD
                              that is correct
