Originally posted by Bamer
View Post
Trying to go the other direction -- how much water volume/flow/pressure is needed. If 2-3 jabscos aren't enough, is the engine-driven impeller (at idle) closer, or still not in the ballpark? Is there a middle ground before getting to the heavy-duty jet thrusters (which rely on a 480amp motor, I get that).
When you get up around 4-500 amps with 3.5" inlets, we get the great videos of boats spinning in circles, just not sure that's what is fully needed? Or is it? IDBoating, is that the conclusion you reached eventually, it just takes something that big?
Better way to say it maybe -- would a 200amp/2.5" create enough thrust to overcome a breeze? 100amp/1.5"? Just wondering what minimum viable would be.
I don't quite have the expendable income to do a bunch of testing unfortunately, and I get in a lot of trouble when I drill holes in the boat, so hoping to only have to do it once...
If I'm just way out of my element on the math on this, let me know, physics in college was a long time ago and I was a bio major.
