Looks great so far. Well done sir.
Winter project has started
Did you test your switches yet? Mine all work except for the light that should come on when you turn one of the pumps on.Originally posted by adamsjstt View PostSwitched out the switch covers for ones that matched the factory switches. Notice the lettering is in the square lens on the factory switches. Finished up all the wiring and the plumbing for the fill pumps and the starboard side rear vent, and drain lines . I have the c/v in the vent and fill lines as high as they can go so that no standing water will be left in the lines.
Tigé Jedi- Jul 2010
- 4305
- TN USA
There's likely an "extra" connector on the switch for the light. This enables you to control the light separately from the switch position, if desired.Originally posted by skippabcool View PostDid you test your switches yet? Mine all work except for the light that should come on when you turn one of the pumps on.
Yes mine all work just like factory. You have to run 2 diodes per switch . One from the fill pump to the led connector and one from the empty pump to the same led connector both thru a diode so the power doesn't back feed to the other pump.Originally posted by skippabcool View PostDid you test your switches yet? Mine all work except for the light that should come on when you turn one of the pumps on.
Lake test last weekend and everything worked like it should. Only issue was that I had a couple small leaks at the check valves. The hose was a loose fit over the check valves when I installed them. Today I reclamped all the check valve connections and applied some 5200 before I slipped the hose on. I also made the drain line holes in the rear compartment panels bigger so that the hose and fitting could sit closer to the floor and allow the bags to empty more. Next I plan to add 2 side sacs next to my u shape sac and piggyback the fill and drain lines with inline valves for when I need extra bow weight.
