I consider myself pretty experienced navigating my Z3,which can beast on windy days, and I would love to have the option. However, no way am I paying anywhere near $10k for the option. I have heard many say that if you need this option you shouldn't own a wake boat. Personally, I think that is a ridiculous statement and am all for progress and making things easier. Plus the easier it is the better chance I can take some time off behind the wheel.
Reverse Thruster assist
Originally posted by jmoore15 View PostI consider myself pretty experienced navigating my Z3,which can beast on windy days, and I would love to have the option. However, no way am I paying anywhere near $10k for the option. I have heard many say that if you need this option you shouldn't own a wake boat. Personally, I think that is a ridiculous statement and am all for progress and making things easier. Plus the easier it is the better chance I can take some time off behind the wheel.
Sent from my iPhone using TapatalkBABz - babzusa.com
Austin, TX
Tigé Jedi
- Jul 2010
- 4303
- TN USA
Originally posted by Dandy View PostHere is an aftermarket options for $4200
https://sideshift.com/monohull-bow-stern-thrusters/
More detailed
https://sideshift.com/monohull-bow-s...tern-thruster/
That's more than most starters pull to start your engine.
Originally posted by IDBoating View Post550 AMPERES OF CURRENT?!? Even the smallest model is 400 amps!
That's more than most starters pull to start your engine.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Just took a Regal 2800 out last week that had a bow thruster. Was actually really cool to basically parallel park. Come up next to dock with a little reverse and wheel turned away from dock, throw a little into bow thruster at same time and boat just walks straight sideways. Cool stuff.
Boat showed up and left with customer pretty quickly and isn't want we normally carry in the Regal line, so don't have much info on it, but can say that amp draw was super high on the bow thruster it had. If you ran it sustained it would drop voltage to 11.9 while running the engine. Would also cause any other finction in boat to underperform when it was in use. All LED courtesy light and many other things would underperform when in use. Can't imagine how a poor little 80-90 amp alternator is going to do with that. Gotta be fielding like a SOBLast edited by freeheel4life; 08-12-2017, 05:21 AM.
Originally posted by IDBoating View PostGreat, but how long can even a dedicated Group 24 sustain hundreds of amps?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Tigé Junkie
- May 2013
- 920
- Central MN
Anyone know if they may have a secondary alternator on the MC/Nautique with factory systems that would be a dedicated charge to that circuit?
Sent from my VS995 using Tapatalk"I think I am pretty smart for an idiot"
Tigé Jedi
- Jul 2010
- 4303
- TN USA
Let's run some numbers here. 400 amps at 12VDC is 4800 watts, which is around five horsepower. Does it really take 5HP to impart rotation to a wakeboat hull? I suppose if you want it to spin really fast, but for docking purposes?
I have an old trolling motor lying around. It has a 6 inch prop (just measured it) and connects to a battery via what appear to be ~14 gauge wires so it probably maxes out around 15-20 amps. I bet if I hang that off the transom it will spin the boat. Not very fast, but I bet it will move. 20A at 12V is 240 watts, which is about 1/3 HP. Do you really need 15X that much power?
Tigé Jedi
- Jul 2010
- 4303
- TN USA
Originally posted by Dandy View PostAnyone know if they may have a secondary alternator on the MC/Nautique with factory systems that would be a dedicated charge to that circuit?
I got to drive a G23 last weekend with the thruster on it. Let's just say it was cool, really cool. Especially how Nautique has it integrated. I agree it's still too expensive, but it works and nicely so. Nautique has it tied into the shifter and steering. It's not an on-off, it's thrust is proportional to how far you have the wheel turned. When engaged, it only comes on when in FWD or REV below 5mph. When in Neutral, there are buttons on the dash to run it either direction. G's are big heavy boats, this thruster can spin it in its own length and at a pretty quick rotation speed too.
Tigé Jedi
- Jul 2010
- 4303
- TN USA
Welcome to the world of driving a jetboat! We used to have a Seadoo Challenger 2000, powered by a Mercury V6 with a Mercury jetdrive, and nothing beats a thrust reverser for maneuverability. As you said, you can turn such a boat in its own length. I still miss that little 20 footer....
