Need to pull the motor on my 2000 21V due to a cracked something or bad gasket somewhere. Have everything out of the way (wiring harness, etc.). I need to know what to pull. Can I just separate the block from the bell housing or do I separate at the trans? Help as I want to have this on the water this summer!
Also, for parts. Can I use GM or high quality aftermarket parts (bearings, gaskets, etc.) I plan on going as deep as need be after I see what is causing my milkshake oil.
