At what point does the TAPS setting in a profile actually get set? I'm having issues with speedset where it is not engaging so I thought I'd try a profile. I'm not even sure the ballast are filling when activated.
Tige Touch profiles
One thing I really don't like about the Tige You profile settings is that it's not clear when it becomes engaged or disengaged. It appears to be tie to the speed set function, but it's not explained anywhere. I also find if I make changes to the Tige You profile (i.e. alter the TAPS setting), the update won't "stick". I've yet to find a way to accurately and consistently use Tige You.
But as Koolaid says, the speed control has a giant green ON when it is engaged.
The SpeedSet "ON" indicator goes green if I hit "On" I think that just means not Off and will engage (supposedly) upon reached speed.Originally posted by KoolAid View PostIf the system is activated (green I believe) you give it full throttle or at least more throttle than what it takes to get to that speed. It should hold. If you are seeing speed on the speedo, most likely the paddle wheel is working properly.
The full throttle bit kinda sucks for wake surfers who like a slow pull up. How do I set it once the desired speed is reached?
