RZX2 with Raptor 400 Won't Turn Over
    Hey all,
    I have a 2018 RZX2 with the Raptor 400 with an intermittent issue. Some days the boat will run fine with no issues. Other days the boat will die then not turn over at all. All accessories work, it's not a battery issue, but when I turn the key, the boat does not crank at all. Some days it will start up again after an hour or 2, some it won't start at all. This past weekend I was stranded on the lake, got towed to dock and put boat on trailer, still wouldn't start. Then when I get home an hour later, it fires right up. I've checked for loose wires, fuses, etc. but all is in order. Wondering if it might be something with the Livorsi throttle and neutral safety switch. Any ideas or experience with this?
    The no crank is a symptom of a bad Livorsi throttle. You also mentioned that it will die. That does not sound like the common Livorsi throttle problem. If your 2018 Raptor is like my 2015, there is a fuse/relay box at the back of the engine above the transmission. The stater relay is located there. You can jump the relay and see if it cranks. I was able to do this with my boat to get me through the summer and then sent my throttle to Livorsi for repair in the off season.
