not an expert, but believe that pressure forces the rings to expand and seal the chamber. an engine at idle with no movement would have some leakage around the rings, especially over a winter. remember that rings are not a solid circle but have a gap cut in them to install them. the liquid fogging fluid would be able to drain past that.
it is not uncommon to have, especially high psi(turbo/supercharged) engines to have leakdown percentages in the double digits.
