Just bought a 2002 21v riders edition from car auction. They say it was winterized and mechanic did everything to it. What is the process I need to do now to get it ready for the water? Any tips or secrets to get it to running at its best?
Just bought a 2002 21v.....Need advice
I'd check the drain plugs in the engine, exhaust manifulds, water pump and possibly the fuel cooler. Yours is a little newer and the changed the number of plugs.Originally posted by brook1724 View PostJust bought a 2002 21v riders edition from car auction. They say it was winterized and mechanic did everything to it. What is the process I need to do now to get it ready for the water? Any tips or secrets to get it to running at its best?
I'd ask them what they do to winterize the boat (the mechanic, that is). Normally, it's just a matter of draining the water out of the engine block and sometimes they fog the cylinders. My advice would be to get a fake-a-lake (looks like a plunger with a hose connector) so you can start it up with water running through the cooling system. If you do this, DO NOT PUT THE BOAT IN GEAR and don't rev the engine up over 2000 RPMS. You can then inspect the cooling system for leaks.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
I agree w/ Dogbert.. I had a 01 21v limited.. dont know what motor your runnin but i had a merc cruiser and had 5 "blue" wing-nut drain plugs in my motor to pull when winterizing..Originally posted by dogbert View PostI'd check the drain plugs in the engine, exhaust manifulds, water pump and possibly the fuel cooler. Yours is a little newer and the changed the number of plugs.
