I have a 1998 2200I WT with a MERC 350 I am looking for a impeller that will last. Don't they make one that will not ruin when you use the fake a lake? It take a little time to get the water up there.Anyone have any suggestions?
Impeller went bad!!
May be time for a new impeller housing, should take a close look at it for grooves, scoring, and discolor.Originally posted by Thomas Chobot View PostI have a 1998 2200I WT with a MERC 350 I am looking for a impeller that will last. Don't they make one that will not ruin when you use the fake a lake? It take a little time to get the water up there.Anyone have any suggestions?
Not if you get good volume and pressure to it, it should work just fine. May want to pull the hoses from the trans cooler and back-flush, a slight restriction here may be just enough to starve the impeller when on the fake-a-lake.Originally posted by fleetpaint View Postwill using the fake-a-lake hurt the impeller?
Another simple trick is to undo the raw water intake hose and just shove the garden hose in and turn it on and forget the fake-a-lake. Works great if it's not to hard to get to the hose.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
You amaze me w/ your knowledge...That is an awesome idea. That would be so easy to rig up too.Originally posted by chpthril View PostMay be time for a new impeller housing, should take a close look at it for grooves, scoring, and discolor.
Another simple trick is to undo the raw water intake hose and just shove the garden hose in and turn it on and forget the fake-a-lake. Works great if it's not to hard to get to the hose.Dale
2000 21i Tige
Install a perko flush pro, it has a fitting for a garden hose, and also has a built in check valve so that the system doesn't have to prime, essentially keeps the whole system pressurized and your impeller will not have to run dry. There is a little key that you can put in to open the check valve if you need to for some reason. I am a big fan of them.
