Battery Selection/Replacement
    I have a 2015 Tige Z1, and here in MN we have to do a couple extra steps for winterization. Unfortunately this year the batteries didn't make it through the cold winter as I disconnected, but didn't remove them....won't make that mistake again. The factory setup is two batteries in parallel, one is a deep cycle and the second is a cranking/starting battery. I know they have the dual purpose batteries now, has anyone tried these instead? I would run two dual purpose batteries in parallel.
    #id
    The factory setup on a 2015 should be a blue sea Dual Circuit Plus OFF/ON/COMBINE and an isolator. Batteries should not be wired in parallel as one is dedicated to cranking/running boat, other is dedicated to house loads.
    If you boat does indeed have the 2 batteries wire in parallel, then they do need to be identical in size, type and age. 2 dual purpose would be good.
    So if it is the above described OEM setup, I would stick with a cranking and deep cycle.
      #id
      Thank you for the info!!
