I have a 2009 22ve, alpha z tower. ....on the tower mounting base, there is a big flathead screw near the hinge point, which can be turned into/out of the tower. what does this screw do and how should it be set?
alpha z tower
Tigé Jedi- Jul 2010
- 4274
- TN USA
It's the hinge. Should never need "adjustment".
I'd be scared to remove it to add Loctite. There are some really powerful springs under there, and their force probably bears on that hinge point. You might not be able to line things up again to reinstall the screw. I suggest looking for a set screw of the proper diameter and installing THAT with Loctite over the top of the existing screw.
Tigé Jedi- Jul 2010
- 4274
- TN USA
Maybe release the tower so it can pivot, and have someone pivot/lift/move it around while you try to tighten it. I'm wondering if that screw/hinge is under a lot of load and things might get easier if someone else is bearing that load for a moment.
