2020 RZX crossover line and drain plugs
    I need help confirming that the cross over line does not exist on a 2020 RZX raptor 400 engine. I pulled the floor up and don’t see this line. I drained the debris filter and found 3 other blue drain plugs. Am I missing one and does it have the crossover line? I feel that should be an easy line to see but I just don’t.
    thanks!
    #id
    It is there, connects the exhaust manifolds.
      #id
      Thanks. I will look again. Should be easy to see but I guess I missed it.
        #id
        Lee, do you have a picture of where it is located?
          #id
          It is right under or just on top of the v-drive.
            #id
            Well, you this is what I have. I pulled the hoses from the debris filter on either side of the V-drive. I can’t find a line otherwise. I pulled 3 blue plastic guys. I guess that’s all I have… any other advice?
              #id
              Look at the exhaust manifolds, on the rear side of the engine, front side of the boat, do you have brass plugs or a cross over hose connected?
                #id
                There are 2 brass plugs. Hard to get to!!!
                  #id
                  So, you need to remove those. You do not have the crossover hose.
                    #id
                    That’s gonna be fun!!! Lol
