2007 22Ve Speed Control Adjustment
    Hi All,
    It has been a while since I have been on the forum. Mainly it has been since 2017 since our boat has been on the water. I have seriously been considering selling it, and probably will, but our family is going to rent a lake place for a week and I figure it would be a good time to get the boat tuned up and get all systems verified before parting with it.
    The last time we used it, I recall that the speed control (Speed Set) did not hold speed very well, it would speed up and slow down. I had replaced the paddle wheel with the Nautic Logic GPS unit. This I don't believe has anything to do with it as it just provides a more accurate speed input. Is there any way to adjust the response rate on Speed Set? On a boat about 10 years ago, we had perfect pass and we could adjust the response speed. I would like to slower the response speed so it isn't constantly hunting.
    FYI: We are running the old tried and true 1235 prop on this boat. I figured it would mention it as it may get asked.
    I am working on getting a service appt. to have them go through all systems before we get it on the water. Maybe my family will fall back in love with the water and I can keep her.
    Thanks in advance for any help
    -Dan
    #id
    The actual speed holding logic is in the engine ECM. The "speed-set" set, speed up and speed down, is simple commands from the touch pad. And, the system does need an accurate speed input, so the paddle wheel or GPS signal is a major factor. With that said, the speed and ECM rely on the same signal, so if the speedo is erratic, then speed-set would be also.
    So if you can set the speed set, speed up and speed down, then it seems the issue lies somewhere else then the speed-set.
      #id
      Did you purchase the patch cable for factory installed speedset
      Sent from my SM-G970W using Tapatalk
        #id
        I purchased the kit specific for 2007 Tige. It was complete plug and play, all connections mated up as instructed.
        In addition, I do have a spare Speedset keypad, but it doesn’t sound as if that would be the issue.
