I have a 2002 tige 21v riders edition with a mercruiser mag mpi towsports. I am getting a strange engine warning beep. It beeps for a few seconds when driving and then stops, then a minute later beeps and stops. All gauges ook okay. Temp is okay, oil pressure okay, batt okay. Any ideas on where to start????
MYSTERIOUS BEEPING
You may want to check the connections at your starter also.Originally posted by Fit to be Tige View PostCheck your connections to the battery again. Mine did this twice and freaked me out, thinking I had an issue. Same deal where everything else was perfect except for the warning beep. I checked the connection to the battery and it was just a little loose. No issues since. Good luck.15 Escalade ESV-Black
08 RZ2-Blue
How old is your boat and does it beep twice above a certain RPM range? If it does this periodically every time you're above 2500 RPMs, it might be your fuel pressure regulator. That happened to me last year. There's a thread on this somewhere and if your Mercruiser is more than 8 years old, it probably is due for replacement. The only way to know for sure is to have the code checked by a service technician.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
Tigé Expert
- Mar 2008
- 1396
- The Sunshine State
- 2000 Tige 21I Riders Edition, 1980 MC Stars and Stripes
This is true also a fuel pump (low pressure) starting to go could give him the same beep. The pump would be priming off and on instead of keeping constant flow. If the high pressure pump starts to go it would be running bad, if at all.Originally posted by dogbert View PostHow old is your boat and does it beep twice above a certain RPM range? If it does this periodically every time you're above 2500 RPMs, it might be your fuel pressure regulator. That happened to me last year. There's a thread on this somewhere and if your Mercruiser is more than 8 years old, it probably is due for replacement. The only way to know for sure is to have the code checked by a service technician.
Mine just started beeping at higher RPMs (2500+). It ran just fine, but I backed it off just as a precaution and had it checked out. It will gradually deteriorate. The fuel pump was just fine. The fuel pressure regulator is jiust a membrane that will deteriorate, especially if there's ethanol in your fuel.Originally posted by Fast1911 View PostThis is true also a fuel pump (low pressure) starting to go could give him the same beep. The pump would be priming off and on instead of keeping constant flow. If the high pressure pump starts to go it would be running bad, if at all.
How can you tell which it is? And other than a beep, what are the symptoms when it starts to deteriorate or fail?Originally posted by dogbert View PostMine just started beeping at higher RPMs (2500+). It ran just fine, but I backed it off just as a precaution and had it checked out. It will gradually deteriorate. The fuel pump was just fine. The fuel pressure regulator is jiust a membrane that will deteriorate, especially if there's ethanol in your fuel.
Where is the site and how did the tool work for you?Originally posted by venetrex View PostI am going to chk all connections and such. I found a site to purchase an adapter to be able to scan the mercruiser computer for $199.00. I believe that's a deal.Mike Allen, Tigé owner since 1997
