I have a 2019 tige r23 with the metal tower. It has brackets to attach speakers. Are there wires readily available? There are already 2 speakers. Upgrading to 4
Adding speakers— help
Pop the plugs from the wires holes on the other two speaker perches and see. I think pre-wire is standard, but not 100% sure.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Historically, if Tige pre-wires a tower, the pairs are wired in parallel somewhere. So the installation is mostly plug-n-play. I have not gotten my hands on a 2019, so I can say 100%.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
So 2 pairs up the tower and paralleled to 4 speakers? Other words two amp channels running 4 speakers?Originally posted by wired1236 View PostThey are prewired but in parallel. Keep that in mind when planning g for an amplifier.
Yes, the amp can power the 2 additional speakers.
The pre-wired tower should already have the each pair wired in parallel.
No, you will not be bridging the 2 channel amp.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
