I see what looks like the other end dangling on pic 3 in the port locker. Unless your head has been swapped for something other then a clarion marine, it will have the mating connection in the back. There wont be a "cable" other then the Y, if there are two remote AT the back of the head to plug in. With out a transom remote, there may not be a Y AT the back of the head. The Y would be behind the helm where the TT and helm remote come together.
Tige Touch Control
if you do not have a transom remote then there will not be a Y-Cable. Just the the 8 pin DIN connector from the back of the CMD6 would plug into the 8 pin DIN connector that goes to the TT. You either have a bad CMD6 or the 8 pin DIN Extension cable to the TT.Last edited by RZRindy; 05-30-2018, 03:09 AM.
Ben,
Had to read your post a few times and look back at your pics,
In your first pics, plug those 2 together.
Then behind the radio in your 4th pic(my 1st - cable circled), that cable plugs into the black cable coming out of your CMD6 I have a arrow pointing to in my 2nd pic and circled in my 3rd pic(stock Photo). You need to take off the black plastic wire cover, you will find the 8 pin din cable buried inside the wire cover. Its in there 100%.Last edited by RZRindy; 05-30-2018, 04:06 PM.
So is the helm remote working now? If not, unplug that one connector under the helm and try the drivers remote again.sound control on driver side.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
There is also this module under the helm. It's usually buried in the harness above the screen. After talking to Justin I ordered one as I thought this was the culprit (had all the same complaint you have except that issue was intermittent). After finding it under the helm I found that the plug was just loose. Once the plastic tab clicked it never had the problem anymore.
PS, that part number on the sticker is Tige's part number.
Installed the new module. Still nothing. I also found a second module unplugged, the same. So i guess the previous owner already had that issue. I know he installed a new clarion before i bought it, could it be the clarion againLast edited by Ben_DipWrap; 05-31-2018, 11:29 PM.
What about the helm remote?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
You tell me, you said you had a helm remote in your first postMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Not sure I know what you have. There is either a Clarion wired remote or the Tige Touch.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
