What's a good replacement for the Clarion CMD5? I would love Bluetooth.
CMD5 Replacement
Im 99% sure that the CMD5 has the old 6-pin remotes and cables. So even sticking with Clarion, you would also be upgrading a transom and helm remote if equipped. For this reason, I suggest a universal blue tooth receiver Such as the Wet Sounds BTVC or one of the other model used by JL/Metra/Cerwin Vega. The Wet Sounds offers volume and track skip, where as the others are a set it and forget it receiver. These units will easily interface with the CMD5's rear red AUX inputs.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Yes, you just need a 3.5MM male x RCA stereo cable for the wet sounds BTVCOriginally posted by jaceaser View PostYes you are correct the aux input is two cables. Is the Wet Sounds BTVC compatible with it, if so, it seems like a pretty easy install?
They are likely taped up in the main harness and hard to see, but they are there. They have red leads (not plugs but the wires).Originally posted by jaceaser View PostThanks, I just went back there to look where are the AUX inputs? I've found the manual, but it doesn't have a diagram of the back of the unit.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
