What are folks using for safety cables / chains for the bow-to-trailer connection in addition to the winch strap? Looking for something that won't scratch up the trailer too back (coated chain, coated cables etc). Also, anyone with the VX figure out how to use transom straps on their trailers? My trailer attachment points are such that the strap would have to go around the VX to connect to the rear transom eye bolt.
safety chains and transom tie downs
I just used a chain and hook for the boweye too the trailer but one thing I've noticed on my boatmates is they're more for a piece of mind than anything, by that I mean the little trailer hook that the chain attaches to would break if the load of the boat were placed strictly on the safety chain. As far as rear transom tie downs how far are you trailer?
I added a coated steal cable with a snap hook (like the one on the winch strap) for the bow. Has just enough slack in it when the winch is tight to hook it on the bow eye. Then use standard transom straps that fit in between the teak and the hull. Not sure how you would have to do it with the VX.
Boatmate ratchet style transom tie downs would probably work...can't remember I'll get criticized for this as normally I'm all for securing loads properly and anal about how it's done. I think they will be for a peace of mind more than anything, the weight of these boats dry and then loaded the amount of force that it would take to make once bounce would have to be extreme. I think if it it's that extreme those straps aren't gonna stop a whole lot, yes I've seen the pictures of boats of the trailers from accidents but I guess to eaches own.
Tigé Junkie- May 2013
- 920
- Central MN
MN,
Thanks for posting these, this will be a huge help. Is the "U" shaped bracket already part of the trailer, included with the tie down, or did you have to have it made?"I think I am pretty smart for an idiot"
yes, there's already a "tab" welded to the trailer that I connected the brackets to. Here's link to the brackets
http://www.fleetfarm.com/detail/boat.../00000000024912013 Z3 - Electric blue and black
- 920
- Central MN
This is what we did for our bow strap. We purchased a set of coated trailer safty cables. Installed one to the loop on the winch post (felt alright with this since it is all welded to the frame) using a chain mender link. We wrapped it around the post for a few reasons...1: to keep the chain mender tight, which will hopefully prevent too much paint chipping
2: to shorten the length of travel in the event the winch strap does break.
For the transom tie downs, we plan to use mnpracing's set up."I think I am pretty smart for an idiot"
