O.K. now I need some info. I have an '05 24V with factory ballast installed. There's two front, and two rear tanks. My question is: How much weight (or gallons) do each of these tanks hold? I didn't recieve anything in any paperwork when we bought the boat. Can anyone answer this ?
Ballast on an '05 24V ?
Rival is custom. Whatever sacs or tanks you can fit. I have Fly High sacs. 2 x 450s in the rear and the bow sac which it probably 4-500. I'm looking to upgrade my rear sacs to 750s (it'll fill the entire rear compartments if they are completely full). I'll have to counter it with another bag up front or I may add some weight from www.pop-products.com
I have a 22V and the V-Drive compartments are the same size.
Tigé Jedi- Feb 2004
- 5553
- St. George, Utah
The U bag I put up front is not likely that big. I bet mine holds only 250-300 pounds.
The bags I have in the back are a custom surf sack on the port side that holds about 1500 pounds. The starboard is a V-drive side sack that is about 400-450. I can still keep most stuff in the storage with a sack that size, plus that is enough to make a formidable wake for wakeboarding. I only fill the surf sack a little when wakeboarding.Be excellent to one another.
