I have a 1998 tige and look for some help or advise. I just bought the boat 3 months ago been out a couple times and notice it takes on water not a lot but after hr or so the pump kicks on. I looked under boat and notice the propeller shaft isn't in the center of the copper fitting on the boat (not sure what it is called) it is rubbing on the side. Not sure if there is a bearing going bad or a seal. The boat runs fine doesn't vibrate or anything. I am looking for some advise and if I can fix it myself or not.
1998 Tige Direct Drive propeller shaft alignment
Thank you guys for the advice. The next chance I get I will look in to the shaft packing. Is there any maintenance that I should look into my boat has around 530hrs. I changed the oil in it after I took it out for the first time. It has a little bit of rough idle to it when I am in a no wake zone. Again thanks for your guys advise on the shaft packing.
