transmission slip
    Would someone be kind enough to send me this bulletin? I would really appreciate it.
    Thanks,
    emboemail@gmail.com
      please send it to me as well.
      byrdbd2003@kconline.com
      Thanks in advance.
        Is the bulletin online somewhere that I can read it?
        Thanks
          All it says to do is to check and fill while you are on the water. Next time out, bring some fluid with you. Warm the boat up, come to a stop and get your fluid and funnel ready. While running, put the the boat in gear, neutral, reverse, neutral. Shut off, check the fluid, add, repeat process until the fluid is up to the full mark.
            Service Bulletin
            Could someone please send me this service bulletin? I have had some trouble with my transmission slipping (which I thought was prop cavitation) and when I checked the transmission dip stick it was a 1/4 full. This service bulletin might fix my issue.
            I have a 2002 Tige 2300V
            matt.snow@trane.com
            Thanks,
            Matt
              If anyone who has not received a service bulletin yet, PM me w/ your email address and I will send it to you.
              Dale
              2000 21i Tige
                slippage service bulletin
                Can someone please forward me the service bulletin on correct trani fluid amounts.
                jedjalu@gmail.com
                  Could i get a copy of the service bulletin as well please!!
                  zac.hopson@gmail.com
                  thank you
                    Me too please.. Copy would be nice
                    Dgalindo@erahelicopters.com
                      Could I get a copy of the bulletin as well please.
                      joshua_113@hotmail.com
                      Thank You.
                        Is there anyone who still needs this? Send me you email address and I will forward it to you.
                        Dale
                        2000 21i Tige
                          I do Dgalindo1987@yahoo.com
                            Would you please send me the SB? Thanks
                            homermutt@gmail.com
                              Would you mind sending me the SB please, ar1rider@gmail.com
                                Could someone please send this to me as well?? mdelleman@gmail.com
