Ok, there's a sticky thread on the Maintenance & Care Forum that has a link to a site that will give you a part number. If you have your engine serial number (usually right on top of the engine), you'll get the exact part number.
If your engine is the 350 Merc Mag MPI and the raw water pump looks like the pic the no.s are probably:
raw water pump - 46-807151A 9, Go2Marine 77494, 5/16” - center pin, 5/8” - adjusting nut,
impeller specs - 2 9/16” dia, 2” wide, 8 blades, 3/4” shaft, single flat
impeller - 47-59362T 1, Sierra 18-3087, Go2Marine 77527
Where is this sticky that you are refering to? I have looked but can't seem to find it.
Grab the serial number off your engine to be sure. My 2000 20i apparently has a 1999 5.7 engine in it, and the 99 impeller is not the same as the 2000. Just an FYI
The purchase of the backup is hard to buy for the prices and cost of the production. The account of the prices and Oxbridge proofreading reviews is termed for the candidates. The medium range is followed for the accumulated items for the market.
2000 20CI Missouri Ozarks. Good to have a spare. Does your new boat have a new impeller? Better to change on the trailer than on the lake. I had my favorite marina change mine when I got the boat. I change it every other year myself now. U tube the process. Easy repair. M&M DSC_2898.jpg
