Originally posted by da.bell
View Post
EK Ballast Install
Agreed, lesser of 2 evils. I wonder if a mushroom thru-hull would salve it, and leave the system as is?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Just double checked G's ballast thread, both have a scoop installed backwards.Originally posted by da.bell View PostI thought he had the mushroom thru-hall hardware.
That is what G used......
Actually you would need 3 check valves.Originally posted by xpjim1 View PostYou will only need 2 check valves per pump. One between the manifold and the pump and one on the vent line before the T with the drain line. Or if you fill and drain from the top of the bag you could get away with one check valve on the vent line and fill and drain through the thru hull. By filling and draining from top of bag you might lose a little water in the bag but not much. I am taking off my check valves on my fill lines since tehy are higher than the bag
Here is second option the diagram
Last edited by eks; 04-17-2008, 05:18 PM.The laughter of the world is merely loneliness pathetically trying to reassure itself. - Neal A. Maxwell
I see no need for three check valves. G said the amount of water lost out of the bags was minimal and they topped off quickly. Just side not depending on what MasterCraft boat you are looking at depends on if they drain from the vent hole or from the bottom of the boat. the one I looked at drains from the bottom of the boat. This can be corrected easily and drain from the side of the boat using the vent that is already installed. You would not have to create another hole in the boat any where at this point. It would all be placement of check valves. If I get the time I will draw it up and post it. It will be this evening.www.automarinecare.com CWB, ACME, FlyHigh, Merc Marine, PCM, Marine-power, WETSOUNDS, HSE Volume Controls, Kicker, Sony, Samson Sports, and many other marine parts or accessory's.
Tigé Jedi- Feb 2004
- 5553
- St. George, Utah
If you put a check valve between the pump and the manifold, then you cannot drain since these pumps drain out of the same hose that they fill with. Water has to go both ways at that point.Originally posted by xpjim1 View PostYou will only need 2 check valves per pump. One between the manifold and the pump...
This system does not have a true 'manifold'. I assume that you mean the collection of PVC immediately attached to the through hull?
One question no one has asked here is this: All of this puts a strain that is pretty significant on the check valves, for a significant amount of time. Are the check valves durable enough that they can handle this? I have not heard much of check valve failures, but I am sure it might happen.Be excellent to one another.
My pool has a check valve that failed after 8 years. I think it failed due to excessive chlorine and the fact that the spring mechanism was not well designed. I have a flapper valve now and it works much better, not to mention improving the flow of water.Originally posted by talltigeguy View PostIf you put a check valve between the pump and the manifold, then you cannot drain since these pumps drain out of the same hose that they fill with. Water has to go both ways at that point.
I still don't see the need for any check valves. If you see the automatic system in the MC boats, you'll notice that they are always topping off because there is always a little backflow.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
If it were me I would put flapper check valves and only flappers. The beauty of this system is that you can build it the way you feel most comfortable with. You get the basic parts and add accordingly.
I personally think that check valves are not needed and I wonder if you could drain from the top of the bag which I bet you could. If you can I would fill and driain from there and leave it that way, then run with it, topping it off as needed. It is not like you are going to run out of water when on the lake to top off if needed. I personally would you the KIS theory. KIS. but if you really want me to I will work on a design with check valves.www.automarinecare.com CWB, ACME, FlyHigh, Merc Marine, PCM, Marine-power, WETSOUNDS, HSE Volume Controls, Kicker, Sony, Samson Sports, and many other marine parts or accessory's.
I would think draining from the top of the bag would cause issues if you used more than one hose into the bag if you were vented at all.Originally posted by SPBFAN View PostIf it were me I would put flapper check valves and only flappers. The beauty of this system is that you can build it the way you feel most comfortable with. You get the basic parts and add accordingly.
Also, if you don't have vents coming out of the side of your boat, how do you know when you're full?
I still think you're better off not having check valves, with the exception of a check valve for the vent (to avoid sucking air).Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
