I will get it to you. Its pinned on my desktop because that screen basically has a "final version" of software unless they ever tweak it. Super sad part though, I'm guessing it still will have the lower current limit. Still that's easy to work around.
Couple of quick questions
You do a helluva job at keeping everyone on track!! I would be anywhere near where I am, without you, and a couple of other guys on here.Originally posted by freeheel4life View PostJust trying to do my part to keep the Tige fam boating and the stoke level on high. Especially for the Mountain West guys with short seasons!
Id draw right off the large red B+ helm BUS supply cable for the relay's pin # 30.Ok, relay and fuse it is. Where do I pull the power from??Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Maybe I’m picturing this relay wired different then. My head says:
30- to battery
85- ground
86- Blue/black stripe (TT2 side)
87- Blue/black strip (transom lights)
I power the relay to battery and ground, and just cut the 12v+ going to the lights and put the relay inline.
Or will that still overload the current?
I don’t think I ever got my BT working right, I just plug into the glovebox, so it doesn’t kill my battery anyways. I’ll just load it, and be done.Originally posted by freeheel4life View PostKoolaid would know better on software but I think some of the final updates for your screen addressed some BT audio issues. I'd say it wouldnt hurt having the final version on your screen. That way lin the future if you have issues the convo doesnt start with "what's your software version"
30- Fused B+ Constant (sits there and waits to go across the switch in the relay to the lights.
85- Switched power from PDM
86- Constant ground This will cause the coil to energize when you turn lights on at the screen and close the switch from 87a to 87
87- Switched power that will get wired to the lights.
Glad to hear it surfs again
Perfect, I think I have it (not a promise I won’t be asking anymore dumb questions). Thanks again, you guys, I would definitely be losing my mind over this, by now! Once again this forum is a huge resource for owners! What the hell did we do before the Internet!!??!!!
