Thank you for the feedback. Another project to add to the to-do list once my barn is up this fall!
2001 23V rebuild from the ground up
Meant to ask on the HPDE, did you buy something like marine board (StarBoard) or just a generic HDPE sheet? I have seen a pretty wide range on pricing between the two options. Knowing most HDPE is just that, HDPE, and marketing gimmics to up pricing, I would expect a generic HDPE sheet should suffice. My only concern over the engine cover would be the heat coming out of the engine compartment possibly causing the plastic to warp/bend. I think over the storage compartments heat should not be so much an issue.
