It takes about 3. Min on the front and about 5-7 min on the rear. If I could figure out my iPhone on how to get pics to Tige owners I'd had a ton of pics up already
2014 Changes? Who knows what
Your filling a 1400 lb sac in 5-7 minutes from the stock system? No way. I filled a 930 from a toss over with 1200 gph that wasn't pumping water thru an already filled tank at that takes 10 plus. It takes longer than that to fill the standard 350's with the surf ballast.
Travis,Originally posted by Travism View PostCan you eleborate on your extra pump setup ? I would like to do that to mine.
We've fixed up a few tige owners with supplementary fill and drain pumps as well as transfer pumps. It can be done without adding additional intake thru-hulls. You can even tie the new pumps into the existing pumps, so its all still controlled through the TT.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
