So I went to Lake Powell and had a great time.
Trailer is a 2006 Extreme TA with 2007 Maxxis tires and torsion axles and 4 wheel disc brakes.
The stretch of road from Lake Powell to Kanab, Utah is brutal. Rough as crap, 100+ degrees at the time we are leaving, and 70 MPH the whole way (OK, I was only supposed to go 65).
We stop at the Pizza Hut in Kanab for grub. I do a walkaround on the tires because the road has already taken tires from me before. I find that my right front tire is very hot, noticeably warmer than the others. The tread is bulging in the center all the way around the tire. So I figure I caught her just before she was about to blow. I change her out in the parking lot and figure all is well. Previous owner had told me the tires were only a year or two old. I notice the numbers indicate that the tire was manufactured in 2007.
The wife then says: 'I meant to tell you that when I parked the trailer at the marina, I thought it wierd the right rear tire was off the ground, even though the trailer was on a completely flat parking surface'. Hmmmm. I won't be able to test this out until I get to our local lake, and unload the boat, which might be a week or two from now. When weighted with the boat, I cannot tell a difference.
When I get home, the right front tire is again noticeably warmer than the other tires, but thankfully it did not blow, or get funny looking.
I am theorizing that my rear torsion axle is failing and all of the weight is on the front tire on that side, thus producing more heat and stress. I do drive with a slight downward slope on the trailer, but it is not severe. If that were the culprit, I would expect it to occur on both sides. The affected wheel rotates freely when jacked up. Both tires on the other side feel like they are the same temperature.
Is that possible, and is there a way a guy with moderate mechanical experience, and ordinary tools can check out this? Or is it better left to a dealer?
Are all the bolts in place on the leaf springs and axle mounts?
