Tige Alpha Z Tower removal
    Can anybody help with me how this is done? I have a small crack in mine I'd like to get fixed. Also, guessing to cut the bolt holding the tower shorter so it doesn't happen again? Looks like it hits the other side unnecessarily which would cause some wild forces where it cracked.
    Thanks,
    Nick
    It's been a few years since I've done it....so I'm probably messing up some instructions.
    You're going to have to remove the gunnel interior pieces so you can access the spring assemblies used for lower the tower. Once you get those out you need some long bolts that you thread in so you can "cage" the spring assemblies. Once the assemblies are caged you can remove the cables from the arch and then remove the spring assemblies from the gunellls and lift the tower off.
    Can you post a picture of the crack and the bolt that you said needs to be shortened?? Lots of people didnt realize the hinge pin bolts were a left hand thread on one side of the tower and right hand thread on the other so the would overtighten it and it would cause the base to crack
      Send me a message and I will email you the removal instructions to make it a lot easier
      Oh Yeah!
        Were you able to figure out the removal of the alpha z tower?
          Some of those guys aren’t around here much anymore, but I have the instructions from Tige, in an email PDF, if you send me your email, I’ll send them to you.
            Zackdogg,
            Would you be able to send me that PDF if you still have it? I cracked my base last week. Tried to lay down the tower and the threaded inserts in the tower fell out and caught the base enough to crack one. crying in a corner still.
              Zackdogg,
              Please send me the instructions also as my spring assist cable just broke after I was getting my tower base crack welded.
                Zackdogg,
                My tower completely cracked one side while trailering so I have to remove the whole tower.
                Please send me the instructions also.
                Thanks
                  Could you also email me the instructions?
