tried to find pre existing info on this on the forum and came up mostly dry, hoping there's good info from the experts on here. My port side actuator failed this past weekend, dealer is booked up at least a month. So to get back on the water surfing goofy im hoping to do the replacement swap on my own.
A few considerations: first, I welcome any tips or suggestions to make sure all goes well. i assume i will need to pull the wires through the hull and reseal (3M 4200?), but other than that looks like a really straightforward job. Also, does anyone know the model number of lenco to order? i had GSA installed over the offseason, so not sure if that affects this. finally, I'm hoping dealer will reimburse me for the actuator and continue to honor warranty. Anyone have any experience with diy work that should be covered under warranty?
thanks in advance!
thanks in advance!
