Decided to mount the thru hulls for venting and draining for both front and rear sacks toward the front, 2 on each side, and a 1 1/4" thru hull to a manifold to feed 3 impeller style pumps.
Winter project has started
Tigé Jedi
- Jul 2010
- 4303
- TN USA
Originally posted by jason@wakemakers.com View PostNice, having those thru-hulls further forward is going to help a lot. Are you also going to cross your lines over to the opposite side?
Tigé Jedi
- Jul 2010
- 4303
- TN USA
Originally posted by jason@wakemakers.com View PostI agree, one or the other is usually sufficient.
I'd do one or the other. And putting my money where my mouth is, I did the forward thruhulls and kept the hoses shorter.
Either way, though, the cool part is doing the project in the first place. I absolutely love this stuff!
Originally posted by WABoating View Post...and if we accept that, then crossing over just adds more hose and increases the frictional losses, thus taking longer to drain the sac(s).
Both work fine, so its splitting hairs.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by adamsjstt View PostHEY CHPTHRIL can you tell me what issues you had when using the fly high check valves with impeller pumps? Is the problem solved using your duck bill style? If so I might need to get some of those duck bill valves from you.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Working on the manifold. I plan on running a couple pieces of 2" pvc under the tees down to the hull to help with supporting the weight of the pumps and glue it down with liquid nails. I still havent received my pumps but i measured everthing and this should work. There is a steady uphill flow from the ball valve to the last 90 then i will tilt the tees up slightly as well. Hows it look?Attached Files
Tigé Jedi
- Jul 2010
- 4303
- TN USA
Definitely looking good. Be really careful with your elevation and that monotonically increasing height, as you described. You've got a lot of distance between the outer hull surface and that last pump.
Love the photos, keep 'em coming!
Looks very good. You have given me a good idea of starting point and layout. I will be so intersted in the progress.
chptril what kind and where should the check valves be placed in a system like this? What are the "duckbill"type?
Also has anyone used a coupler after the valve and before the manifold ? This seems like a good idea in case one has to remove the manifolf or valve and thru hull for some reason for servise or replacement. This would help eleminate having to cut things up. Just a thought. ???Wake Up or Stay On Shore!
