I have a 95 tige 2002 fslm and the steering seems very stiff to the right. When we got the boat the salesman told me it was supposed to pull right because it makes it easier to pull a straight line through a slalom course, which makes some sense. At the time it was slightly harder to steer to the right than it was to the left. Over time the steering to the right has gotten very stiff.
My question is there any kind of maintenance needs to be done on the steering in my boat? There is a hard plastic hose under the dash that has a coil running through it. The coil moves as you steer the wheel back and forth. Are you supposed to grease that coil? If so how and with what kind of grease? Any help will be appreciated.
