So... I have my boat at the dealer for the throttle handle for the 3rd time. I asked them to look at a leak that I have coming in from the prop shaft seal. They said, "it probably just needs to be tightened." Cool, easy enough.
I get a call today from the dealer and it is bad news. The seal is bad. It is a seal that Tige only used a couple of years and stopped using due this very issue. So, now they say they have to replace the seal assembly for a different kind of seal because they don't make that one any more. Since thay need to disassemble the V-drive assembly it going to run $600 to $700. 4 hours of labor and $200 for the parts.
Does this sound right? If Tige stopped using this specific seal because of this issue, shouldn't this be a warranty issue?
A little insight would be great. Thanks.
