Thanks FIC and kko.
Impellor gone again
There's a fix for this. I think Moki had the same problem with his after he replaced his alternator. On some Mercruisers, the alignment was off and so it would burn up belts like there's no tomorrow. My friend had the same problem on his 21v.Originally posted by formandfunction View PostIf it makes you feel better surfdad my boat eats serpentine belts on a regular basis,no impellers though.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
An engine will sometimes roll backwards about a 1/4 turn when it is shut off. The cause of the back-roll is compression in one of the cylinder. As it rolls back, the veins of the impeller will flip. When the engine is restarted, it will sometimes correct it's self, bind up and cause the belt to slip, or just turn in the wrong direction till you notice the engine running hot.Originally posted by illiniboarder88 View PostSorry to hijack, but does anyone know what causes the impeller to "flip"?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
