Very strange feeling. Cruising at 30 to 35 mph the boat starts slowing down like the engine, or trans, are being held back. ( 2002 21 v Merc 350 mpi - 50 hrs ) all fluids are good, temperatures normal. If your try to throtle up when it begins to slow, the boat strains even harder. Please help, any sugestions?
Boat slows down
Before anything, make them change the fuel pump. Do not let them install a pump booster. That was the original bulliten that was of no use. They must test the pump or install a new one first. How can a fuel tank be faulty? As long as it holds fuel and there is a hole for the fuel to run out into the supply the only thing left is the pump. My '02 problem was the original pump.
