Ok, so we went out last night and about 15 minutes into the ride, the alarm starts going off. I check the temp gauge and it's about 170 (right where it's supposed to be). Oil pressure is good. Oil and tranny levels are normal, V-Drive looks good. It's an intermittent beep that goes to solid alarm when i go above 3200 Mph. I still have plenty of power in all ranges. The only strange thing is that the drivers side exhaust manifold is cool to the touch and the passenger side is very warm, but not hot. All battery connections ok, no loose wires under the dash.
I'm thinking marginal impeller that may have partially shredded with some blockage.
Thoughts?
Thoughts?
J/K
This "breakdown" might give you enough power to convince Mrs Dogbert that your family needs a new RZ2...
