2009 RZ2 with PCM 343. 707 hours.
We were cruising along surfing the first run of today when the engine seemed to just stop running. My wife just about ran into the back of the boat. As we coasted to a stop, the engine was running rough at low RPM's and then stopped running after about 20 seconds. It wouldn't start back up and had to bum a tow back to the dock. To be honest, we had the stereo cranked up so if any alarms sounded, I wouldn't have heard it. I've look around different forums looking for a place to begin, but I can't find a thread to start me off. Here are the symptoms from the best I can tell:
1. The oil was a little low. I pulled the dip stick and the level was on the low end of the range. I added a pint to bring it back to normal. Still won't crank.
2. The oil pressure is zero when I turn the key on. I don't know if this is normal when the engine is not running.
3. When I tried to re-start it, the starter motor will spin until I turn the key off. It won't even begin to catch
4. There is no oil in the engine compartment. (I think this is a good sign).
5. My fuel tank is at 3/4
Not sure if I have given enough information to get me started. I am wondering if I have a problem with the oil pressure sensor, high pressure fuel pump, fried the engine.... I'm moderately skilled with working on the engine, but I don't have a clue where to start with this one. Help...
. Fixed the ground and have run four days without issue.
