Where do I need to install my “tee” to steal water for the seal? Haven’t seen any installs that look like my setup. 2006 ve pcm 330
I assumed where I have circled in blue, where water dumps into the exhaust. Someone said directly after the raw water pump, which would be in the green. Not a lot of room to work in there, and would be more likely to have interference from the belt/pulleys.
but again, for the above reason, I doubt it really makes much difference. And every connection is another potential point of failure, so if it was me personally I'd favor a single fitting. Which is what I did on my system as illustrated in that thread. By the way, that was the exact spot recommended by PCM personnel for my engine. YMMV, etc.
