I've had my 2003 22v (6.0 GM LS Engine) for about 3 year now with no issues and know will not start or turn over. I tried to start it for the first time in about 2 mouths this weekend to find out it will not do anything even after bypassing the neutral safety switch. I have power to all gauge but my RPM gauge is constantly beep with no display. Could I have a bad RPM gauge does it have to communicate with the ECU to fire up. The only way I can get the starter to turn over but engine still doesn't fire up is to run a wire from the ignition side of the neutral safety switch to the starter wire.
Any info on this issue after 4 hours of checking voltage and wiring I can find any issues.
