2017 Tige RZX2 Engine Fault Code SPN 441 FMI 4
Tigé Jedi- Jul 2010
- 4305
- TN USA
Murphy (maker of the helm system) says SPN 441 means "Auxiliary Temperature #1 High (Most Severe)".
I presume there is a temp sensor somewhere on the engine and it believes it's beyond what it considers its absolute max safe value.
Sorry, that's all I have on it....
J-AL it's going to be the temp senders in your exhausts. They will be covered by warranty. You aren't the first. LKG here on the forum has had the same problem this year too.
http://www.tigeowners.com/forum/show...-SPN-441-FMI-3
There's more infoLast edited by freeheel4life; 05-15-2017, 01:11 AM.
Thanks for the info! I hope they tell me that they can send me the sensors and this is something I can take care of myself. It's almost 400 miles all together and many hours of my time just to take the boat to the dealership. That's not counting miles and time if they have to keep the boat.Originally posted by freeheel4life View PostJ-AL it's going to be the temp senders in your exhausts. They will be covered by warranty. You aren't the first. LKG here on the forum has had the same problem this year too.
There's more info
Sent from my SM-N900P using Tapatalk
It's super easy job to do. I am not sure if you will get it warrantied if a "Indmar dealer" doesn't do the work. Regardless, for the 400 miles worth of gas, your time, and ease, you could buy them and install them yourself. Don't think you will be able to clear codes without diacom though. Not sure if they will eventually clear once engine hits Closed Loop + adapt mode or not, but don't think they will.
Well, that's another problem in itself! I am NOT going to be happy if I have to trailer my boat to the dealership for something I can do myself and especially just so they can clear the codes... absolutely ridiculous if that turns out to be the case....I will find out on Tuesday, and I'll be sure to update.
battery off 2 min.... Battery on 5 full ignition cycles firing the motor and stopping it. Should clear the faults unless the problem still existsOriginally posted by freeheel4life View PostIt's super easy job to do. I am not sure if you will get it warrantied if a "Indmar dealer" doesn't do the work. Regardless, for the 400 miles worth of gas, your time, and ease, you could buy them and install them yourself. Don't think you will be able to clear codes without diacom though. Not sure if they will eventually clear once engine hits Closed Loop + adapt mode or not, but don't think they will.
Germaine Marine
I'll try that. It will be a week before the dealer gets the parts. Indmar said I could use the boat in the meantime.Originally posted by elevatedconcept View Postbattery off 2 min.... Battery on 5 full ignition cycles firing the motor and stopping it. Should clear the faults unless the problem still exists
Just a heads up on this issue for 17 Raptor. Indmar was only paying out warranty if the sensors failed. They just released another bulletin that says they will now pay warranty on all affected serial #s for anyone that wants it done regardless if sensors have failed yet. Guessing that enough in service engines have had issues. So if your serial # is between 198408 and 203133 you can take your boat in and it should be warranty. Indmar only pays .2 hours per sensor but on Tiges it shouldn't take long to change the way the floor lifts up. Other boats are going to be a bit more difficult.
If you are in this batch of serials and it hasn't failed I personally would wait until you have boat back at your dealer for oil change/wint/ or other service and request they do it then. Would also call ahead to make sure they order both sensors and have em on hand.
Happy boating!
Once I received the error codes and contacted my dealer they ordered the sensors and installed them 2 weeks later. He was at my dock for about 30 minutes. Removing and reinstalling the flooring took longer than changing the actual sensors. I'm fortunate as I am located between my dealer's home and his dealership :-)
I don't understand why they had to take the flooring up. I thought theses temp sensors where right underneath the engine cover towards the front of the boat?Originally posted by LKG PH Creek View PostOnce I received the error codes and contacted my dealer they ordered the sensors and installed them 2 weeks later. He was at my dock for about 30 minutes. Removing and reinstalling the flooring took longer than changing the actual sensors. I'm fortunate as I am located between my dealer's home and his dealership :-)
Orange circle is just the Deutsch connector. The actual sensor is down in the elbow, pre cat but after the exhaust manifold v band clamp. They thread into the double walled cat tubing. Honestly don't know what size wrench offhand. Indmar is knocking it out of the park on this. Been on the ball, and while some have had problems, we have quite a few boats in service that are in the affected serial # range that haven't had issues.
Thanks. I realize that is only the connector that's circled and the sensor is below that. That's the only picture I had at the time of post.Originally posted by freeheel4life View PostOrange circle is just the Deutsch connector. The actual sensor is down in the elbow, pre cat but after the exhaust manifold v band clamp. They thread into the double walled cat tubing. Honestly don't know what size wrench offhand. Indmar is knocking it out of the park on this. Been on the ball, and while some have had problems, we have quite a few boats in service that are in the affected serial # range that haven't had issues.
