Had a weekend boating trip half-ruined after my 2002 20i started overheating. It is fine when cruising or at WOT, but at very slow speeds (slightly faster than no-wake, and at no-wake and idle), it overheats. Gauge goes up and I get a warning beep.
So, in short, if the engine is running faster, it is fine. Running slower, it overheats.
Everything else gauge-wise seems fine.
I got under the boat and looked at the intake area, no obvious obstructions. I'll take out the tube that goes from the intake to the pump (is that the Impeller? Front right of the motor, connected to the intake tube?). I'll check the tube for any obstructions.
If no obstructions, would it be the impeller/water pump is going out? Or does this motor have a thermostat that might be sticking or something?
Is there anything else to check before removing the pump? Would I REPLACE the pump, or would there possibly be obstructions inside of the pump that could be cleaned out?
Similar location in a car.
It's a 2002 20i with Mercruiser, but the engine was replaced last Spring (by the previous owner). I believe they only replaced the engine and left all the accessories that were "original", though.
