i tried resetting. How do you reset that type. The others have a lever that you push back in. Do yolu push the red button in because i tried that and it pops back out.
On mine there is a lever. It looks very similar to yours. Is it broken??
i did find the lever. But the real problem was that there was a wire shorting out/pulled out behind the safety stop/ignition kill switch. Once i fixed that and reset the lever, all worked.
