I took it to dealer late last year because of running bad, it had water in the gas and we removed all the bad gas, It has a 350 Vortec in it, We put a new dist. cap and all that and it ran good at the dealership, we put non ethanol gas and two cans of seaform as directed by dealer. We just pulled it out and washed it and the dang thing wont start !! Any help would be appreciated on what might be wrong.
Z1 wont Start !!!
Describe no start? Engine spins over wont start or engine wont spin over?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
I checked the kill switch and it is in good working condition. I tried to start it again today and it would run for three seconds and shut off , I turned the key off and then waited and then started it again and it ran for three seconds , it did it everytime. But here is the thing tho I would turn the key let it run thru its protocol and the engine would start and run for a few seconds then not turning the key off and letting it run thru the protocol just trying to start it , it would just turn over !!! Could it be a fuel pump or coil What do you think.
Tigé Jedi- Jul 2010
- 3795
- TN USA
Sounds like fuel supply to me. Just a feeling without being there to diagnose.Originally posted by COFTYSZ1 View PostI checked the kill switch and it is in good working condition. I tried to start it again today and it would run for three seconds and shut off , I turned the key off and then waited and then started it again and it ran for three seconds , it did it everytime. But here is the thing tho I would turn the key let it run thru its protocol and the engine would start and run for a few seconds then not turning the key off and letting it run thru the protocol just trying to start it , it would just turn over !!! Could it be a fuel pump or coil What do you think.
