Temperature Gauge Stopped Working
    I have a 2006 24Ve and the temp gauge stopped working. No overheating issues but the gauge just dropped to the peg. Engine is a 5.7 MP and I am now chasing the issue. A couple of questions? Where is the ECT located on the engine and also how do I trouble shoot to see if it is just a bad gauge?
    Thanks for any help you can give
    CHall
    take a look at this. look at page 2-10 in section 2.
    http://www.marinepowerusa.com/pdfs/M...ice_Manual.pdf
    2011 Tigé RZ4
    www.re-viveupholstery.com
      Thanks for the information. Easy to locate and no visible sign of any issue on the connection there. Now I will need to trouble shoot the gauge or the wire back to the gauge.
      I saw a couple of threads about grounding the wire to check if it is a gauge or a wire problem so I will try to work my way through that.
      CHall
        Tap Tap it's back.....?
        Update: 8-20
        Ran the boat and checked connections....last resort I tapped on the glass and now it works.
        I will make this a winter project and take it apart and check all the connections.
        Thanks for the help
        CHall
