help finding a paddlewheel/depth finder for 02 22i
    Need help with part number for the speedo/depth finder for a 22i 2002 model. Mine has finally broken off and is flapping.
    Is it on the back of the boat or mounted in the hull under the engine. By flapping I get the impression its hanging off the back if so I doubt that is a factory item. I have never seen them set up that way. Should be using a paddle wheel type transducer mounted in a thru hull tube under the engine if its OEM.
      this is an airmar part... it is mounted at the rear of the hull. dont know if its factory or not? the cable has part no. C47 C1225 Im needing the whole kit with bracket.
        got it figured out. Its an airmar p32
          Airmar does not sell directly. You need to contact their North American distributer Gemeco. www.gemeco.com I worked with them a few years back on a discontinued one for and older data log on my Cruiser boat and they were very helpful. If you have the part number also check ebay.
            ordered it earlier from amazon for 75 bucks
